Gearbox Noise Measurement Units
Manufacturer just sent me a new box which they claim was 100% quality checked (see previous thread). The documents say this unit ran on the dyno at 7 Pc/M^s-2 compared to a standard of 10 Pc/M^s-2.
Does anyone know what units these are? I did some research and found that gearbox noise is sometimes measured in acceleration units such as meters per second squared. Perhaps that is what M^s-2 means? Sound pressure is also measured in pascals but the abbreviation for pascal is Pa, not Pc. Maybe the document has a typo?
RE: Gearbox Noise Measurement Units
h
Generally, when acceptance testing a gearbox, you're looking at specific frequencies and modes. These are usually gear meshing frequencies (or sometimes rolling element bearing passing frequencies). Each gear mesh will have a specific meshing frequency at a given input speed, and if there is excessive vibration being generated at that frequency it's usually a good indication of problems with one of the gears in the mesh. Housing mounted accelerometers are usually used for data acquisition.
Measuring radiated sound pressure is a less direct method of doing the same thing, but would not require instrumenting the gearbox.
Hope that helps.
Terry
pC/ms^-2, picoCoulombs per meter per second squared.
Ted
M
Dr Michael F Platten
Nothing to do with the actual vibration, as this is normally all allowed for in the measurement chain that leads to the waveforms and spectra in g's or mm/s etc.
