Anchors for precast panel bracing
Does anyone have experience with using/specifying Excalibur screwbolts to fix the bracing props?
By the National Code of Practice deformation controlled, including self-drilling, anchors are forbidden.
The Excalibur is a bolt that cuts a thread into the concrete and the manufacturer claims it is therefore an undercut type anchor, which is allowable.
I suspect he may be correct, but require more evidence than his say so.
This is for a job in Brisbane.
www.screwbolt.com.au
RE: Anchors for precast panel bracing
I agree with your description; the problem is that the CoP and AS3850 rule out using self-drill anchors, hence the re-branding as undercut type.
I will see if I can find it.
http://www
htt
ANY FOOL CAN DESIGN A STRUCTURE. IT TAKES AN ENGINEER TO DESIGN A CONNECTION."
As it stands I'm not allowing the use of the Excalibur.
It will take more than a distributor's email to convince me that it can be classed as an undercut anchor suitable for this purpose.
However, from the literature I've seen it appears to be a good product and it's probably not the last we've heard of it.
