Torsion Spring for Opening Lid
I am designing a lid that pivots out of its frame on one end by means of two torsion springs around the pivot axis. The lid weighs 0.4 pounds and the center of mass is 7 inches away from the pivot axis. Thus, the moment about the axis is 7 x 0.4 = 2.8. Since there will be 2 torsion springs, I am looking for springs with a 2.0 in-lb rating to be safe.
My question is this: does the leg length of the torsion spring have an effect on what torque specification I should be looking for? For example, McMaster 9287K145 has a torque rating of 2 in-lb, but its legs are 1.25" long. I can only accommodate a leg length of .75". If I chop off the leg length, will the McMaster spring still be 2 in-lb? Or am I thinking about this incorrectly?
RE: Torsion Spring for Opening Lid
ht
Ted
The spring legs considered added coils to the number of coils of the spring body and their length is included in the active number of the coils of the spring. Therefore, by shortening the legs you decrease the number of active coils. At the same angular deflection the spring will give more torque and larger stresses in spring wire.
Correct, but the spring stress of 2 in-lb would not change.
And the equivalent loss of the number of coils due to a decrement of 1 inch of leg is
.5/(pi*d)
d= pitch diameter of spring
If you apply the 2 lbf-in torque on the spring the stress will be the same. But usually the spring designed for same angular deflection of the lid therefore, the torque will be higher, the stress will be higher. May be slightly higher but still higher. If the spring is subjected to cyclic operation that may affect the life cycle.
I used to do this type of problem a lot (2-3 times a month over 4 years). We always started with a graph of torque vs. lid angular position. First curve was torque due to lid weight & CG position (which lessens as lid raises). Second curve was spring torque, which was linear with a slope of k and offset from zero by preload * k. This graph would show necessary preload and spring rate needed to lift lid and would also reveal if lid would close on its own or have a balance point. Note: Graph does not account for momentum.
Ted
