Air flow rate
Air flow rate
Air flow rate
On every leaf blower available, the package indicates a maximum air flow rate.  I would like to determine the validity of these claims.  Any suggestions on the best means of doing so?
RE: Air flow rate
I believe the equation for air pressure, say in a pitot tube is P=0.00256 * V^2  where (V=mph, and P=psf).
You may be able to rig up a monometer with plastic tubing, and say a funnel to direct the air into and calucate the head pressure in inches of water...and convert back to V.
Maybe??
RE: Air flow rate
Cut circular hole on top of the nozzle, install a hopper filled with ping pong balls, and get a radar gun.
RE: Air flow rate
Wind tunnel and some CO2 ice, or .. a very big cigar.
RE: Air flow rate
Hot wire anemometer?
Good luck,
Latexman
RE: Air flow rate
Get a big plastic bag, measure the volume, empty the inside air and then blow it with the fan while taking the time. You get your answer by doing a bit of simple math. The method is called ABFM, W version (Advance Bag Flow Measurement, Waterpipe version).
The method basis is available at:
http://www.lbl.gov/Education/ELSI/Frames/pollution-measure-air-f.html
