Tsai Wu failure
Tsai Wu failure
Tsai Wu failure
I will model a laminate while using the Tsai Wu failure for my result output. I have entered all the necessary values of my laminate. Do I have to write any other data in the Nastran deck to get my solution? Which output file do i have to use?? op2 or xdb??
thanks in advance!!
RE: Tsai Wu failure
f06 should be gtg
