How can i draw a part from a picture sketch
I wondered if there is a way to draw a 3d part from a pic sketch .
i did the method that import the picture then sketch it
but it doesn't accurate if i want to make an assembly part
check this pic http://img151.imageshack.us/img151/7721/aaabi.jpg
RE: How can i draw a part from a picture sketch
Rob Stupplebeen
cause of the dimensional mismatch of each part
Rob Stupplebeen
check this file plz how can i do it
You should know one overriding basic size important to the design. Bring your picture into a sketch and scale to match that design parameter. Then model the parts relative to this picture (not absolutely reproduce). Multibody solids techniques would probably be the best way to model this so that you can easily build and check the relationships between parts. Then push out the assembly and individual parts when done.
I think the first thing I would do is go through the built in Help>Tutorials. Otherwise this is just art - not engineering geometry that you can easily and predictably edit to get the parts to assembly correclty.
So is this a WWI aircraft model? You could probably laser cut from the jpegs, if you cleaned them up. We used to do that with Corel draw.
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
I brought the picture in the sketch and multiplied the width by the value (2.55/45) then i sketched it so that made it more accurate , but i had a problem in the assem
check it plz how can i exceed this
I'm doing this as a project too , It's Daddy-0 525 I don't know the original airplane but I think it's look like the Zero fighter
That is not a Zero, THIS is:
http
SW 2010 SP 4.0
