Shared sketches
Shared sketches
Shared sketches
Is it possible to share sketches in NX6? I've created a sketch but it's self intersecting so it won't allow me to do a cut extrude in one go. want to be able to select a section of the sketch to put the cut extrude in but it doesn't allow me. what's the best way around this? i know i can create 2 seperate sketches but i'd like to find out if i can avoid having to do this.
RE: Shared sketches
If you set your selection intent to 'single curve', you can select individual curves from the sketch to extrude.
RE: Shared sketches
you make it look easy. thanks very much. works a charm.
RE: Shared sketches
I prefer to set my default to connected curves. that is usually what I want.
RE: Shared sketches
The 'Stop at Intersection' option can also be very helpful when working with a complex sketch which is "self intersecting".
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
