ST2 Draft: Fit text in block attributes
Hello;
I started to use Solid Edge ST2 now, and I need to import a large number of AutoCAD files. These files have attributes, some of which have stretched text, what ST2 can not import. Is there some way to "fit" texts in attributes in ST2 Draft?
RE: ST2 Draft: Fit text in block attributes
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
I tried to make some printscreens to explain what I mean.
First, the text attribute in my block in autocad:
This text is fitted using the option below in block properties:
And this is the way that Solid Edge imports the same file:
Again:
Thanks for reply, sorry for my bad english.
Other than that you can change the aspect ratio of the text in Solid Edge:- RMB on the text > Properties > Paragraph > Aspect Ratio.
Try setting it to 0.7, that should give roughly the same scaling, but it will depend how the fonts are mapped.
This needs to be done manually, there is no automatic way when importing.
bc.
Quadro FX4600.
But actually, in this case, I'm working with a text within a block, which does not have the same configuration options of a single text.
In the properties block, as much as in the block editor, I can not change the aspect ratio of a text.
bc.
Quadro FX4600.
