NX Open .NET identifying faces in FEM
Is there anyone who has experience of NX OPEN in NX7.5?
I'm trying to construct a script that will identify geometry such as faces and edges according to attributes (colour etc). The following works in 'Modelling' but I have come unstuck when trying the equivalent in 'Advanced Simulation'
Dim edge_1 As NXOpen.Edge
Dim point_1 As NXOpen.Point
Dim b As NXOpen.Part = workPart
For Each c As NXOpen.Body In b.Bodies
For Each d As NXOpen.Face In c.GetFaces
Dim e As Integer = d.Color
If e = 20 Then
For Each f As NXOpen.Edge In d.GetEdges
edge_1 = f
Next
point_1 = workPart.Points.CreatePoint(edge_1, SmartObject.UpdateOption.WithinModeling)
point_1.SetVisibility(SmartObject.VisibilityOption.Visible)
MsgBox(point_1.Coordinates.X)
MsgBox(point_1.Coordinates.Y)
MsgBox(point_1.Coordinates.Z)
End If
Next
Next
Any help much appreciated!
RE: NX Open .NET identifying faces in FEM
With this statement:
I suppose you meant that it does not work in the Advanced Simulation module?
Also, I am not quite sure what you are trying to achieve with:
CODE
                        edge_1 = f
                    Next
I'm guessing you are trying to print out the coordinates of each edge whose color is 20? In that case, you should try push this code in the for-loop:
CODE
So that it reads:
CODE
                        point_1 = workPart.Points.CreatePoint(f, SmartObject.UpdateOption.WithinModeling)
                    Next
With your current code, it will only report the information of the last edge, and not all of them.
Thanks MarckyMON,
You suppose correctly that it is the Advanced Simulation module for which I would like the equivalent result.
You are also right in that the code would return results for the last entry only.  At present I am only testing a proof of concept, and there is only one face whose colour value is equal to 20, so this is not too much of a concern.
The assistance I would welcome would be the equavalent results for CAE faces & edges in Advanced Simulation, since I can't figure out the hierarchy of NXObjects that would allow me to extract/ identify the features I'm interested in.
Can you maybe elaborate what is not exactly working? Is the script abruptly ending with an exception? Are any edges found at all?
You can use the listing window as a debugging tool.
Marc
NX Software Developer
Sorry - maybe I should elaborate on the process I'm trying to achieve.  Maybe my entire approach could be more efficient...
Ultimately I am trying to identify polygon faces and points within a FEM model that contains multiple CAE bodies.  These features I would then reference to create 1D connector elements (RBE2 etc) in the FEM, and create simulation loads and constraints, and define contact/ glue in the SIM.
So far I have been trying to adapt journal scripts to fit my purpose, however these generally require prior knowledge of the object I am trying to identify; e.g.
        Dim cAEBody1 As CAE.CAEBody = CType(workFemPart.FindObject("CAE_Body(3)"), CAE.CAEBody)
        Dim cAEFace1 As CAE.CAEFace = CType(cAEBody1.FindObject("CAE_Face(1932)"), CAE.CAEFace)
This would return the face I am interested in as the value of cAEFace1.
The area I am struggling with is an alternative method to identify this face.  In the Modelling module I achieved this with the (not very elegant) code above.  When I try to adopt a similar approach in Advanced Simulation module, I cannot find the equivalent members & methods of the CAE objects.
For example, in the following code:
        Dim theSession As Session = Session.GetSession()
        Dim workFemPart As CAE.FemPart = CType(theSession.Parts.BaseWork, CAE.FemPart)
        Dim displayFemPart As CAE.FemPart = CType(theSession.Parts.BaseDisplay, CAE.FemPart)
        Dim femPart1 As CAE.FemPart = CType(workFemPart, CAE.FemPart)
        For Each CAEBody1 As CAE.CAEBody In femPart1. ...
There is no member or method for 'femPart1' that would allow me to search through each body, and then each face within that body so that I could try to match it against a criteria (e.g. colour)
I have had some success with searching objects using:
        theUfSession.Obj.CycleObjsInPart
however I can only return tags, and nothing I can use subsequently.
I have only recent exposure to NX Open, and therefore find it hard to navigate the documentation to find the information I am searching for.
Again, any assistance would be greatly appreciated!
also, you mentioned the listing window.
I've not come across this before - is there anywhere I can find out more info about how to use this?
Is it an NX feature or inherent to .net?
Thanks for your help so far
Problem Solved, Thanks for assistance in the meantime!
CODE
        Dim basePart As BasePart = theSession.Parts.BaseWork
        Dim baseFEMPart As CAE.BaseFemPart = CType(basePart, CAE.BaseFemPart)
        Dim baseFEModel As CAE.BaseFEModel = CType(baseFEMPart.BaseFEModel, CAE.BaseFEModel)
        Dim NULLTAG As Tag = NXOpen.Tag.Null
        Dim objectTag As Tag = NXOpen.Tag.Null
        theUfSession.Obj.CycleObjsInPart(baseFEMPart.Tag, NXOpen.UF.UFConstants.UF_caegeom_type, objectTag)
        Do
            Dim objType As Integer = 0
            Dim objSubtype As Integer = 0
            Dim objectName As String = Nothing
            Dim myBody As Body = Nothing
            Dim myCAEBody As CAE.CAEBody = Nothing
            Dim myObject As NXObject = Nothing
            Dim myMaterial As String = Nothing
            Dim GroupObjects() As NXOpen.TaggedObject = Nothing
            theUfSession.Obj.AskTypeAndSubtype(objectTag, objType, objSubtype)
            If objSubtype = NXOpen.UF.UFConstants.UF_caegeom_body_subtype Then
                myObject = NXObjectManager.Get(objectTag)
                myCAEBody = CType(myObject, CAE.CAEBody)
                MsgBox("Tag = " & objectTag & ", Name = " & myCAEBody.JournalIdentifier)
            End If
            theUfSession.Obj.CycleObjsInPart(basePart.Tag, NXOpen.UF.UFConstants.UF_caegeom_type, objectTag)
        Loop While objectTag <> NULLTAG
Petewirth,
The listing window is an NX feature.
For the NX listing window to be used for output it has to be "opened" with the following...
     theSession.ListingWindow.Open()
Typically this is done once at the beginning of the program.
Then just as you had used messagebox you can construct the output string and send it to the NX listing window where it is appended to any exisitng output there.
    theSession.ListingWindow.WriteLine("Tag = " & objectTag & ", Name = " & myCAEBody.JournalIdentifier)
(word wrap warning!) The example above is one line.
The net_ref.chm (from the t-doc "Automation,NX Open,NX Open for .NET Reference Guide") explains the available methods an properties for ListingWindow.
Regards, Joe
Nice - Thanks Joe!
Pete
