Journal to find and move groups by names to a given layer??
Is it possible, using a journal, to search for a group by name, ie group_a, group_b, group_c..., then move that group as well as its contents to a given layer?
I have tried recording a journal to do this, but it finds the group and objects all individually using a journal identifier, not by name. From the recored journal placing the objects into an array then moving them should be fairly straight forward, workPart.Layers.MoveDisplayableObjects(destination_layer, objectArray1), but how whould one go about finding the group and its contents?
UG NX 6.0.4.3
RE: Journal to find and move groups by names to a given layer??
You might have to access the UG/Open C wrapper functions to solve your issue.
First, you will need to collect (into an ArrayList, for example) all group objects with a specific name. Take a look at the NXOpen.UF.UFObj class to achieve this.
Once you have a collection, then it should only be a matter of moving these groups to a given layer.
HTH
CODE
Dim theSession As Session = Session.GetSession()
Dim WorkPart As Part = theSession.Parts.Work
Dim TheUFsession As UFSession = UFSession.GetUFSession()
Dim NULLTAG As Tag = NXOpen.Tag.Null
Dim objectTag As Tag = NXOpen.Tag.Null
Dim group_count As Integer = 0
Dim group_list() As group
Dim group_member_list() As tag
dim member_count as integer
theUfSession.Obj.CycleObjsInPart(workpart.Tag, NXOpen.UF.UFConstants.UF_group_type, objectTag)
Do
Dim mygroup As group = Nothing
Dim myObject As NXObject = Nothing
Dim group_object as nxobject
Dim group_object_type as Integer
dim group_object_subtype as Integer
myObject = NXObjectManager.Get(objectTag)
mygroup = CType(myObject, group)
Array.Resize(group_list, group_count+1)
group_list(group_count)=mygroup
theufsession.group.AskGroupData(objecttag,group_member_list,member_count)
msgbox("Found group " & mygroup.name & ", it contains " & member_count & " objects")
group_count+=1
theUfSession.Obj.CycleObjsInPart(workPart.Tag, NXOpen.UF.UFConstants.UF_group_type, objectTag)
Loop While objectTag <> NULLTAG
End Function
UG NX 6.0.4.3
