Acetylene Cylinder in Unclassifed Area
Our client wants to put a Cylinder of Acetylene in an unclassified building. The cylinder will be piped out of the building to a laboratory nearby. Does that change the classifcation of the building? There is the risk of gas leakage through the cylinder regulator. Do you know any standard that deals with this specific case?
RE: Acetylene Cylinder in Unclassifed Area
It would be best if you were to go to http://www.eng-tips.com/threadforum.cfm?lev3=84 and pick the code forum that best aligns with the applicable codes in your location (you didn't specify) and post the question there.  Then Red Flag this thread for removal.
