Teamcenter not loading per load options
My default setup is "as saved" in load options, but when loading assembly - Teamcenter loads prior revisions. My workaround is to use load precise option and update structure on each change. Is there something I need to change to get "as saved" to work.
NX3.0.5.3 + TC9.1.3.3
Thank you.
Thank you.
NX3 + TC9
RE: Teamcenter not loading per load options
It happens when I open assembly "as saved" regardless. Both if it is by initiating from Teamcenter without UG already loaded or starting from UG and selecting item from list or recently opened. I was making sure that all right components were in assembly when saving - still on next "as saved" open some of the items were pulled from obsolete revisions. Now each time I have to load using "precise" to assure correct items loading. This is inconvenient because our site standard is "as saved" so I have to switch it each time.
Thank you.
NX3 + TC9
Just for clarification - are these your company defined default load options, or are these the ones you defined as default for yourself? If the prior, then it sounds like your company default load options take precedence over your own.
NX3 + TC9
As Saved can be tricky with NX. If you modify a detail, save it, but don't save the next higher assembly, As Saved will load the older component in a new session of NX. The system is doing exactly what you asked it to do.
If I understand the 'precise' rules of TC, that will load the latest of all components.
There is a difference in Load Latest and As Saved. It takes some understanding for all engineers to understand the rules required for good working tools.
Ben Loosli
Both top level as well as sub assemblies display this behavior. I have entire assembly open when saving and even executed "save all parts" in NX manager but still on next load some older components are being retrieved.
I believe that "precise" loads what is in set precise in PSE which can vary from the latest.
It is strange but those assemblies initially worked OK. At some point something triggers this behavior and past this point each time when loading "as saved" they load some older revs no meter what I do.
I'm hoping there is some setting not set right in TC, so I can request to get it changed, but can't really point it yet.
NX3 + TC9
NX3 + TC9
If it worked at one time, find who made any changes.
Systemwide changes here are required to be documented.
Ben Loosli
NX3 + TC9
NX3 + TC9
Sometimes the complexity of these systems takes a deeper understanding to utilize them to their fullest capability.
Ben Loosli
