Phosphate Surface Finish
I have successfully used phosphating in the past for mild corrosion protection but now I have a part to phosphate that contains a 32 finish on a seal surface. What surface finish can I expect with Zinc Phosphate? Is Manganese Phosphate going to be different?
Mike
Mike
RE: Phosphate Surface Finish
http://www.birchwoodcasey.com/microlok/index.html
