MAVR manual
MAVR manual
MAVR manual
Dear all,
Does anybody have the manual of the MAVR automatic voltage regulator made by Brush?
Thanks in advance
RE: MAVR manual
I think I have a copy somewhere, but it is quite big to upload. Have you asked Brush at Loughborough for a copy?
The MAVR itself is typically just a component of a larger system: the field is often controlled by a large semi-converter (or pair of semi-converters, 'Auto' and 'Manual') which takes a control signal from the MAVR. The basic MAVR is only capable of a few amps. If you are after the full system manual then you're best talking to Brush because the systems are normally tailored to the machine and customer requirements.
RE: MAVR manual
Thanks Scotty, I'll try Brush, even though last time I contacted them I didn't get a very fast respose... smile
RE: MAVR manual
I won't comment... wink
I've found a copy of the file and dumped it on a file host. Not quite as big as I thought.
MAVR Manual
RE: MAVR manual
Thank you very much, Scotty! It's going to be very useful for me. A star for you.
RE: MAVR manual
Not a fast response from Brush, huh?....  Who would'a thought it?
rmw
