Sheets to Solid Bodies
Hi NX'rs,
I have 4 sheet bodies with unique profiles. I now want to make a solid body either directly from the sheet bodies or use them to cut the final profile.
I "sewed" the sheet bodies together, but don't recall on how to make a solid body. Creating another solid body & using the sheets to trim does not seem to be working.
What's the process to create a solid body from the sheets or to use them as cutting tools?
RE: Sheets to Solid Bodies
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I have 6 sewn sheet bodies - 4 sides & top & bottom. Visiually, it looks o.k, but they're still not a solid body.
I've submitted a CAD file for example.
I attempted to upload a NX 7.5 file, but it's not able to upload at this time. I'll have to try again later.
Preferences -> Modeling -> General
...and check to make sure that the 'Body Type' option is set to 'Solid'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
My preferences aren't the issue here in that they are already set to the suggested settings stated above.
If I click in the "sew" feature, all sheet bodies (walls - sides & top & bottom) highlight as they should be. However, it's still a bunch of (connected) sheet bodies.
For whatever reasons, I can't upload my CAD file either, otherwise I would submit for review.
The Examine Geometry check doesn't highlight any issiues or discrepancies.
What might be the other causes?
I attempted to upload my NX 7.5 CAD file for review, but for whatever reasons, the system is not uploading it.
In it's place, I created a small presentation, along with some pictures of my issues.
Please review & suggest
John R. Baker, P.E.
Industry Sector
Cypress, CA
As you can kind of see in the pics, this area has a couple of transition & twist areas.
Initinally, I thought the Through Curve or Through Curve Mesh features would define this area well, but as you can see, some areas becomes "funky" & gives undesirable results.
At this point, I've tried a 100 different ways from creating a solide then, using the sheet bodies to trim to whatever else.
Each process works to a degree, up until that point where I can't control & cant' get my desired solid body geometry.
Obviously, I'm doing something wrong here... I've done similar jobs in the past & didn't have these many issues....
Whatever works - That's the answers I'm seeking...
Thanks again for the assistance...
John R. Baker, P.E.
Industry Sector
Cypress, CA
I compressed the file size whic probably was the problem before that prohibit me to upload the file.
This time, it looked like it worked...
John R. Baker, P.E.
Industry Sector
Cypress, CA
It took me to two dam days & a lot of trial & errors, but somehow, I finally got my sheet bodies to become solid bodies.
However, the geometry is still not perfect, but it's not horrible either.
I used the Through Curve Mesh feature & made 2 halves. Previously, I was sectioning these into 4 walls. For the most part, this seems to work, but for whatever reasons before, it didn't.
Now, if I could figure out on how to get "cleaner" geometry that doesn't over revolve & give a "hump" appearance...
Any suggestions....???
You make it look so easy.... I know I tried something similar several times & I did or still not get the same "desireable" results as you did.
I tried to duplicate your processs, using the same settings, line type selection - Tangent & vector direction. However, my solid faces are resulting in very choppy faces.
See attached pic.
I'll try again in the morning...
I noticed you added a Datum Coordinate System in your example, which is something that I don't have in my model.
What does this do?
Nothing!
The method I used to get a part file which ONLY contained the information needed to model what I had was to export the solid body and all if references to an empty Part file which already contained the Datum CSYS since my Modeling template files all have a Datum CSYS as the first entity just in case I need to for reference when I start constructing something. In this case, it was just there by default and added nothing to the solution.
John R. Baker, P.E.
Industry Sector
Cypress, CA
As far as I can tell, I'm duplicating your process & yet, I'm clearly not getting the same results. Therefore, I guess I'm not duplicating your process.
Is there a specific process that I should be following? I know NX can be sensitive to pick selections, line entity types, etc., but considering this is all from my my model, this shouldn't be an issue.
Anyway, give it shot.
John R. Baker, P.E.
Industry Sector
Cypress, CA
So, this is the trick! I need to change my 'Section Options'.
I'll have to check this when I get back to work.
Thanks agian...
I changed my Selection Options as instructed, however, I'm still not quite getting the results you got.
Compared to before, It's much "cleaner", but the top half of my solid, where the majority of my sections are, is coming out a little rigidity.
I had no problem duplicating your process in your model, but for whatever reasons, something is still different in my model.
I'm selecting my sections from the bottom-up
Selected my two guide curves & changed my selection options.
However, NX is instructing me to first select my orientation, which I simply selected the guide curves.
Then in the Scaling Method area, I am not initially getting the "Uniform" option. Instead, I am getting:
Constant
Blending Function
Another Curve
A Point
Area Law
Perimeter Law
I kept the Constant option.
Changed the Guide area to Manual & Degree to '5'.
The result is a solid that is kind of rigidity.
If I edit my the Swept feature, then it displays "Uniform" in the Scaling Method area.
How can I remove the "rigidity" appearance?
Thanks again...
Yes - That was an option available that I selected.
Are the arrows on all your sections pointing the same way? If not, use the reverse button on the oddball section(s).
If this doesn't fix it can you post another .jpg?
As far as I can tell, I have the same selction process & orientation & Swept Feature preferences.
I attached a zip file with a handful of pics.
Thus far - No!
As far as I can tell, John used the same sketch or line entities that I submitted from my CAD file. We have the same guide point locations & my cross-sections are from the bottom-up, with the vectors point in the same directions.
My select options are now the same, as far as I can tell, which they weren't before.
However, for whatever reasons, part of my solid is coming out "rigidity".
I'm not sure if this is not a graphics thing, but I don't expect that being the issue.
The Design Intent was to layout a handful of cross-sections, then be able to sweep those cross-sections in some way to make a nice "clean" parametric model.
Thus far - That's not working...
If you really need it to pass through all those sections and be smooth, you may need to try plan B. Build it in sections. Use swept along with the bottom 3 sections and top 3 sections and use a command such as through curves or through curve mesh (that allow you to define tangent conditions) for the middle part(s).
I cold do this, but then I loose some of the profile that I need to contrain to. In areas where I don't pick my cross-sections, the solid will eithe result as being over or under - or a combination of both around the cross-sections.
This area is almost like an airfoil where I have to keep a specified profile all the around. I cannot deviate from this if it's not within tolorance.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I don't see what the issue is either. I "think" I did what you did & have my preferences the way you have & yet, as you may have seen in my pictures, part of my solid is coming out "rigidity".
I'm still reviewing, but at the moment, I can't find anything. Perhasp, we have a virtual meeting through Teamviewer or something.
I'm also on the Pacific Coast, so we can schedule.
John R. Baker, P.E.
Industry Sector
Cypress, CA
