Drafting Color Line
Drafting Color Line
Drafting Color Line
Hello to all.
How I can change in the customer defaults menu, the color of the green line of the piece.
So do not have to change all the time?
Thanks for help me.
Best regards.
RE: Drafting Color Line
So do you want to change the color as how it is seen on the drawing?
Hi.
Thanks for answer.
I want that there will always represent the drafting me all the same.
How can Ido?
Best regards.
Work in Monochrome and this will never be a problem.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Hello.
Ok John R. Baker.
But the client does not work in Monochrome
Thanks for help me.
Best regards.
Do you create the drawing or does someone else (outside your company)? Do you use drawing templates?
You can set this up in the customer defaults and the drawing template, but if the drawing is created (started) outside your company it will use their settings instead of yours.
