Natural gas industrial pipe sizing... what method is industry standard
What do people do in the industry these days to size pipe length and diameter and also calculate flowrates based on the btu of the gas and btu demand of the unit. This is going in power plants that ignite the gas to then ignite the main coal fuel. I would know the megawatt demand of the igniter then I find the btu and cfm from that... but then what? Are they using equations and paper or is it all done in computer programs? or? I am trying to get into this and find equations like the Peng-Robinson Eqn and the Bennedict-Webb-Rubin-Starling eqn and dont know if people still use these equations? I am just hoping for a good starting point to begin practice. Thanks.
RE: Natural gas industrial pipe sizing... what method is industry standard
BWR is mainly used for gas compression head/efficiency calculations.
If your pressure is much lower than 2 atm(a) then you can get some really flaky results from the incompressible-flow equations and I generally go to the HVAC folks for their low pressure equations. Compressible flow is really difficult to evaluate and the HVAC industry has done an excellent job of developing correlations that work at the pressures they normally work at.
David
Also I see some of the equations are for horizontal pipes or have a factor for small angles that can be used.... but what about large angles and vertical runs? I solved small simple piping problems in college, but these are going to be more involved.
I just want to know where to start or maybe a really informative paper or book that I can learn how to use these equations... If I cant find a good reference I will prob. go back to the university and ask some of my old professors for guidance... nobody to help me here at my company unfortunately... thanks for all the help so far
Thanks.
right now hiring a consultant would make no sense for various reasons one being we are not getting any of these projects in the near future
