Not able to Add an item to a Selection
Hello All,
Catia V5 R19 on XP64bit
I have recently been on the V5 VBA course, and I'm now writing my first program (how sweet!).
The program is to randomize the colours of parts within a product. The products are loaded from our PDM system (VPM via 3D Com to be precise) and it is likely that there are multiple levels or assemblies within the main root node.
The main elements of the program works, (looping up and down the structure, and changing the colour of a series of part within a flat product structure)
The problem that I have is that the program does not correclty select the part visibly in the catia screen. Interestingly the colour does change, but is not visible on the screen but only in the graphic properties toolbar when slecting the part manually in the spec tree.
Therfore the only thing that is not working is the passing the Added element to the selection for the colour to be visible. Any help would be appreciated, I assume that it is a syntax or a missunderstanding on my part.
Thanks.
[code]
Option Explicit
Dim boShape As Boolean
Dim pdDocument As ProductDocument
Dim selProperty As Selection
Dim lR As Long
Dim lB As Long
Dim lG As Long
Sub Colour_Change()
Dim stName As String
Dim i As Integer
On Error Resume Next
Set pdDocument = CATIA.ActiveDocument
stName = TypeName(CATIA.ActiveDocument)
If Err.Description <> "" Then
MsgBox "No Documents Loaded", vbCritical
Exit Sub
ElseIf stName <> "ProductDocument" Then
MsgBox "This only works for Products", vbCritical
Exit Sub
End If
Dim pdProducts As Products
Set pdProducts = pdDocument.Product.Products
Set selProperty = pdDocument.Selection
selProperty.Clear
Dim gmsShape As Object
Dim refProduct As Product
For i = 1 To pdProducts.Count
boShape = pdProducts.Item(i).HasAMasterShapeRepresentation
If boShape Then
'This works
selProperty.Add pdProducts.Item(i)
lR = CInt(255 * Rnd())
lB = CInt(255 * Rnd())
lG = CInt(255 * Rnd())
selProperty.VisProperties.SetVisibleColor lR, lG, lB, 1
selProperty.Clear
Else
Set refProduct = pdDocument.Product.Products.Item(i).ReferenceProduct
Call LoopProduct(refProduct)
End If
Next
End Sub
Sub LoopProduct(refProductPass)
Dim i As Integer
Dim Test As AnyObject
For i = 1 To refProductPass.Products.Count
boShape = refProductPass.Products.Item(i).HasAMasterShapeRepresentation()
If boShape Then
'This doesn't work
selProperty.Add refProductPass.Products.Item(i)
selProperty.VisProperties.SetRealColor lR, lG, lB, 1
selProperty.Clear
Else
Set refProduct = refProductPass.Products.Item(i).ReferenceProduct
End If
Next
End Sub
