REPLACEMENT OF EXISTING CHILLED WATER PIPE SUPPORT
Hi guys,
I am required to design a steel pipe support of a chilled water pipe which is currently supported by concrete (like a pedestal) elevated around 500MM from the finish floor level. Is there any guidelines how to design a saddle steel support for the chilled water pipe.
I appreciate your opinions in these subject matter. thanks
RE: REPLACEMENT OF EXISTING CHILLED WATER PIPE SUPPORT
There are pre-fabricated pipe supports with load ratings provided by the manufacturer.
