capacity control
capacity control
Refer to API 618 capacity of reciprocating compressors could be controlled by unloading device, clearance pocket and spillback control valve.
If five steps unloading (i.e. 0, 25, 50, 75 and 100% of full flow) are used in combination of spillback control valve, it is kindly requested to inform us about following questions,
1. Which flows are reported as maximum, normal and minimum flow for control valve sizing?
2. Is it necessary to report full flow of compressor as a shutdown case for this valve and consider it to CV calculation?
3. If the response to item 2 is yes ,so which DP will be considered for valve in settle out (shut down)case?
RE: capacity control
