Heat treated 4130 Color Result
I have two different plates of 4130, both heat treated to a hardness of HRC 22, the but it looks like both plates are heat treated differently as the color of the finished plates is different. Plate sample A is a dark gray to black while plate sample B is a light gray.
Is the finished color a result of the quench media? For example one plate could be quenched with oil and the other water or brine?
Initially I though the tempering would effect the color, but given that they both have the same hardness value this maybe not the case.
RE: Heat treated 4130 Color Result
