electrical design engineering books/info
I am trying to locate some books / notes or training materials with step by step procedures along with calculations and examples that pertain to the following subjects that someone might have come across or know of:
Electrical design engineering regarding the design of: low and medium voltage switchgears, busbar systems, power distribution, sub-station design/installation, transformers, cabling, motor control centres (MCC), electrical distribution systems for the power industry, grid connectors, line protectors, fault isolation systems, local distribution systems, design of low and medium voltage power distribution including load flow, short circuit and grounding studies, transformer sizing, cable sizing and pulling calculations and fuse co-ordination studies, switchgear sizing, grounding, lighting, cable trays and conduit layout.
Also: design work for underground and overhead electrical distribution networks, street lighting, and traffic signal activities.
Principles and practices of electrical engineering as applied to the design and construction of an electrical power distribution system.
Design of new pole lines, design of new subdivision shallow service utilities, design of underground systems – both new construction and rehabilitation projects.
Distribution engineering including distribution standards, design, construction, equipment and maintenance pratices.
Methods and materials used in construction of an electrical distribution system.
Asset management in the areas of transmission and distribution.
Sometimes the university bookstores have good books related to the above mentioned subjects. I'd appreciate it If anyone knows of or finds any such books or materials, could they please post with the name and ISBN for them?
RE: electrical design engineering books/info
"THE TRANSMISSION AND DISTRIBUTION OF ELECTRICAL ENERGY"
by H.Cotton and H.Barber ISBN 0 340 147717
desertfox
http://
desertfox
