Flow bypass
Flow bypass
Does anyone know a good way to predict how much gas flow will bypass in a syste. For example We have a duct mostly filled with a pourous medium but there are some gaps around the perimiter of the duct. How can we figure out how much gas flow will actually go through the pourous medium and how much will excape through the gaps.
Thank You
Thank You
RE: Flow bypass
You are going to need a lot more details like dimensions of respective parts of the system and aerodynamic resistance of the porous medium or its composition.
RE: Flow bypass
RE: Flow bypass
Remember that fluids, whether gas or liquid, seek the path of least resistance. As a first order you could try calculating the pressure drop across the gap and then compare it to the pressure drop for the porous medium (which hopefully the manufacturer has provided to you).
However, as cloa said, a lot more information would be needed and, as Mr. BTU said, a cfd computer program would probably be helpful.
From a practical standpoint, if you want the gas to go through the porous mediume, use sealant strips and plug the gaps.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
