Butt Welding of Ductile Iron
Can anybody explain if butt welding for ductile iron material is applicable? What parameter required to obtain good sound weld?
Thanks.
Thanks.
RE: Butt Welding of Ductile Iron
What is the application? Ductile iron can be butt welded but precautions are required, and a high nickel weld rod must be used.
Please visit here for more information and options for joining ductile iron.
http://www.ductile.org/didata/Section8/8intro.htm
Originally, the pipe has a bell and spigot joint. Then, it has been shorten the length as required at site installation. Then, the proposed solution is to join the pieces by butt welding.
Is this a low pressure water supply in soil?
It is a gravity pressure in soil...
Honestly, I like brazing better for most cast irons; less thermal shock , less bevel prep and (most often) perfectly adequate mechanical properties after the fact. If possible, give the certified welder/brazier a test coupon if you're worried about procedure devolpment.
Steve
ICC SI, CWI, UT III, Blacksmith
