overturning stability for a fixed roof tank
Hi all,
I am going to calculate the OVERTURNING STABILITY for a fixed rood storage tank (supported roof).
In section 5.11.2 (API 650, edition 11), we see:
MDL = moment about the shell-to-bottom joint from the weight of the shell and roof supported by the shell
can anyone tell me how I assume the weight of roof supported bye the shell?
we have roof plates and roof structures ( rafter+girders+column).
Thanks all
Thanks all
RE: overturning stability for a fixed roof tank
If you know the geometry, figure the loading on each rafter is equal to the spacing between rafters (which varies along the length) times the plate weight plus the rafter weight, and treat the rafter as a simply-supported beam with trapezoidal loading.
If you're checking for stability, try doing the calculation without including the roof weight. If it passes like that, it won't matter what the roof weight is.
I got it. but I think i have to calculate the detail information of rafter, girder and column.
many thanks again
