AWS D1.5 FCM Handling Requirements
I am looking for where the code states how fracture critical members shall be handled.  I have a situtation where a weldemnt that is a FCM has been handled with a chain and has left chain link 'divots' impressed in the material.
Any direction on where handling requirements are spelled out in D1.5 would be appreciated.  Thanks.
RE: AWS D1.5 FCM Handling Requirements
Is it in the weld or base metal?
12.9- as recv'd inspection of base metal per ASTM A6
I don't know the spec off-hand for surface roughness.
12.17.6- '...Surfaces shall be ground when necessary to facilitate visual inspection and ndt.'
I'd treat it like an arc strike and flush grind it, followed by visual and MT
C 3.10 Arc strikes are removed by shallow grinding
C 3.8 peening allowable when approved
