Templates part in Teamcenter 8.3 and NX7.5
I started a new installation of teamcenter 8.3
I launched tcin_templates_setup.bat without any problem and I found my templates parts in the NX templates folder. but when I try to create a new part I have an error message : "templates are not installed..."
May I miss something after tcin_templates_setup.bat ?
Thanks in advance
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
RE: Templates part in Teamcenter 8.3 and NX7.5
I have setted the variable UGII_TEMPLATE_DIR for NX natif which was in conflict when using NX inside Teamcenter.
So I deleted this variable and everything is OK
Didier Psaltopoulos
I am trying to do the same thing but running tcin_templates_setup.bat -u=infodba -p=****** -g=dba seems not to be working for me. Any idea why? Do you run this .bat from command prompt?
It seems that no files are being uploaded to the database.
Thanks in advance,
Rodrigo
First of all, you have yo open a teamcenter window command prompt. By this way, all variables for teamcenter will be setted.
Then type the following command in this window
cd C:\...\ugnx7.5\UGII\templates\sample
Didier Psaltopoulos
For some reason we don't have TC Command Prompt on the clients, so had to set the variables manually on the windows command prompt. But it worked flawlessly!
Best,
Rodrigo
