Section View - Assembly
Hello folks,
I'm having issues sectioning through an assembly. It seems the sectioning plane (yellow) cannot be adjusted. It way out of size with arrows being to far away from my assembly. I tried resizing the default xyz planes, checked if a part was floating out in la la land, checked the origin point, but still no luck. Any ideas? See attached file.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
RE: Section View - Assembly
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
Mechanical Designer
