Calculating K-Factors
I got tired of teaching my sheet metal vendors how to calculate K-Factors so I put something together for them.  (Most of them just used trial and error methods to develop their flat patterns or blindly used a single value without understanding why and when it was valid!)
There are probably some here who can make good use of it as well so I thought I'd post it.
Enjoy!
- - -Updraft
RE: Calculating K-Factors
Updraft,
Thanks, this looks really good.  One of my first SolidWorks jigs was at a company that was predominately a sheet metal fabricator.  We soon learned that math alone was not enough to get accurate K-factors, as even the type of tooling, tooling clearances, and wear could cause variations.  We created test strips for the various metals and tooling and machines, and finally had a matrix of K-factors to use for a given situation.  After this, it was easy for our shop to hold +/-.010 on 10-16 gauge parts.
Of course this really only worked so well since we manufactured our own parts.  Many times you can arm a vendor with data, but still can't get them to pull the trigger.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
If I have to tell a vendor something so basic, I do not use them.
Updraft,
   I agree with TheTick.  My vendors ask for my SolidWorks files so they can flatten the part and plug in their K factors.
   I expect my fabricators to know more about fabricating than I do.  All I do is accept the SolidWorks default K factor.
               JHG
This comes from the last place I worked where we did or own sheet metal and I had to teach the other engineers about K-factors.  It made a huge difference.
MadMango, you are correct that the particular tooling makes a big difference.  That actually made this type of spreadsheet all the more valuable since it made it easy for the shop to make a few simple measurements and give us accurate K-factors.  I've had shops use this to calculate different K-factors between brake forming and forming in a hard die; different values even though the IBR and thickness were the same.  We even identified differences when bending with the grain vs. cross-grain.  As a result we were able to routinely achieve +/-.004 for most cases (with Cpk=1.33).
I prefer the top-notch vendors as you guys have indicated, but I don't mind helping out the guys I'm forced to deal with.  After all, it is in my best interest to help them.  :)
- - -Updraft
