Reuse Library components in assembly "not found"
Hola,
Lately I've been designing more of our tooling and fixturing in-context with great success. As a result I've been using washers, capscrews, dowels, etc, from the Reuse Library more and more to get an even more accurate model of what we will actually build. Nothing more satisfying than a complex fixture being made, without any surprises or rework, and functioning flawlessly during a first production run.
My problem is that some of the Reuse Library components become unavailable during later sessions. The weird thing is this isn't affecting all components. My capscrews show up no problem, but my setscrews, and dowels will not.
Assembly Load Options is set to "As Saved". Despite that, when I try to display a "greyed-out" component in the Assembly Navigator I'm told "Failed to find using current search options, part left unloaded", then, "This component cannot be made visible. It is in an excluded reference set."
Right-clicking the greyed-out component I have no sign of "Replace Reference Set".
How can I fix this, and why do different components from the library behave differently?
I should point out I'm on NX 7.0.0.9 (NX 7.5.2.5 is on the way
), and I'm fairly sure I added components from the library the same way each time; dragging them from the Member Select window onto the feature where it would be used (ex. a counterbore), letting NX correctly position and orient the component. All I was doing at that point was defining the component length and sometimes the thread pitch.
RE: Reuse Library components in assembly "not found"
that had worked for me
Ben Loosli
I've DL'd NX 7.5.2.5, but we recently decided to upgrade our current OS Win 7 to 64-bit Win 7, so we're holding off upgrading from NX 7. I'll have to DL the 64-bit NX 7.5.2.5 too. I hope we upgrade before the new year. >.<
What could have caused this to be happening now? I've been using fasteners in assmeblies for quite awhile without any problems.
Will NX 7.5 remedy this outright, or will I have to "re-load" all the fasteners then re-save the assemblies?
Sadly, the components from the re-use libraries still will not show up in my assemblies after successfully being added and constrained.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I've tried all three of the Asembly Load Options: From Folder, As Saved, & From Search Folders.
Typically I've been using As Saved. Setting it back to From Folder allowed some re-use components to open, but not others. Weird.
The Re-Use Library was installed natively and is not used in a Teamcenter environment. Could this be causing the problem? I don't remember having this problem with NX 6 though. However to be fair, I don't think I used the library much before Siemens made the full library available for free a little over a year ago.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Somewhere around August last year, everyone lost administrative privileges to their local directories C:\Program Files\Common Files\UGS\Reuse Library\.
That's why some components worked, and some didn't. Fasteners I had used in other assemblies before August were saved within the directory. Whereas ones that I added that were no already in there, wouldn't show. Hence the errors I was getting.
Thanks John for giving me the clue regarding members being saved to the common folder. Everything seems to work fine now.
Now... why/how were the administrative privileges modified last August in the first place?
I'm sorry, but you're on your own for that one
John R. Baker, P.E.
Industry Sector
Cypress, CA
