Equation between Planes
Hello Everyone,
I am trying to use an equation to change the height of a dimension in a sketch that is in relation to the distance between the first plane.
The equation is y=Cos(.25X) where i want y to be the height of the dimension and x be the distance between the planes. I have about 15 different planes using this equation and was wondering if there was a way to have it work.
(I dont want to have to enter a different X value for each one as i will constantly be changing the dimension between the planes).
Thank you for any help you can provide.
RE: Equation between Planes
If it is any help, the first plane im trying to dimension from is the front plane.
How is your plane constrained?  Is it defined as being a specific distance from the front plane?  If it is, then there should be a dimension such as "D1@PLANE1" that you would use in the equation.
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
WOW i cant believe i couldnt figure that one out. I tried a whole bunch of different commands.
Thank you very very much
I typically would put this in a design table.
Rob Stupplebeen
