Channel "10 U 15" Properties. Building built in 1901!
If anyone can help, I am looking for properties of a specific channel.  The drawings I am working with are from 1901.  Yes 1901.  An extremely long time ago.  Drawings are in great shape nonetheless.  Anyway, the drawings denote a built-up column made using (2) channels laced together and they are denoted as being "10 U 15" where the "U" seems obvious for a channel designation.  I am specifically looking for area, moment of inertial, and x any y centroidal axis locations.  Thanks to anyone that can help.
RE: Channel "10 U 15" Properties. Building built in 1901!
The oldest AISC manual I have is from 1949 where a 10", 15.3#/ft channel is shown on pages 30 & 31.
A = 4.47
Ixx = 66.9
Iyy = 2.3 (x = .64")
2.6" flange width, .436" average thickness
.24" web thickness
I doubt that this is the one you want, but it's a start.
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
You might be able to download the Carnegie Steel Companion at books.google.com
SlideRuleEra has some later versions.
http://www.slideruleera.net/
From my 1909 Carnegie, hard copy a single lattice column made up of 2 - 10C15 (12" wide) has the following properties:
A = 8.92 in^6
I 1-1 about the strong axis of the channels 134 in^4, r= 3.87
I 2-2 123 in^4, r=3.72
weight per foot 37.8
flange width = 2.6"; flange thicknesses = 0.24" & 0.633, web thickness 0.24"
Back then the books didn't list all of the info you asked for; the AISC historic manual doesn't list channels.
There is also the possibility that it is cast iron rather than steel.  Do the drawings specify a strength?
BA
Bridgebuster: "From my 1909 Carnegie, hard copy a single lattice column made up of 2 - 10C15 (12" wide) has the following properties:"
That certainly sounds like a match, but how did they make a "lattice column" up?  Sounds like an outside channel riveted with straight plates to a second channel?
bridgebuster, you're sketch is correct, except the channel toe's point towards each other.  The column details also show 2-1/2" wide by 5/16" bars used for the lattice work connecting the two independent channels.  I did not find any notation on the drawings designating the strength and/or material used for the erection of the structure (steel or cast iron).  Thanks everyone for the help thus far!
The attached pages might help with the strength. Can you go to the site to see if the column has the mill's name on it?
I looked in an 1893 & 1903 Carnegie Manual (PDF's). The 1893 doesn't have any latticed column tables using two channels; the 1903 doesn't have latticed columns with 10' channels.
Take at look at the Pencoyd Iron Works (1892)manual - download from SRE's site. They have several tables on steel and iron latticed columns. He also has the AISC historic shapes manual 1873-1952; that's where the attachment came from.
How about a set of calipers and a small drill?
Brad
