Multiple Materials in One Body - Workbench
I'm using ANSYS to do a static structural FEA analysis of a partial knee implant. I'm using an external program to mesh the knee and assign material properties. Because bones have non uniform density, the program also applies individual material properties to each element. After applying material properties, I export the mesh as a .cdb file, and use Finite Element Modeler in Workbench to import the mesh. Here, each element has the appropriate material properties. Next, when I drag the model into a static structural analysis, the materials are available, but only one of them is applied to the whole bone. Is there a way to keep the individual material properties for each element? Thanks!
RE: Multiple Materials in One Body - Workbench
