Motor selection for lead screw system with pulleys or gears
The torque required to move the load on my lead screw (with safety factor of 1.9) is ~250 oz-in.
I need the lead screw to rotate at 1500 rpm (To achieve the required linear speed of 2.5 in/sec, with a 1/2"-10 acme screw)
My initial thought was to directly connect an electric motor to the lead screw.  However, motors that can achieve direct output of 1500 rpm and 250 oz-in torque are slightly too expensive.
I would like to explore a pulley or gear based connection from a motor to the lead screw, but have no idea where to start.
Any advice or direction will be greatly appreciated.
Thank you,
Sean
RE: Motor selection for lead screw system with pulleys or gears
Get a catalog from Browning or Martin Sprocket & Gear.
Read it all.
Mike Halloran
Pembroke Pines, FL, USA
You will need the same power either way.
