Secondary Containment Options
We are still in the brainstorming stage on what we should use to contain spill of Fresh Acid and Spent Acid (sulfuric acid, conc. 91%). The existing primary containment is a steel tank and the existing secondary containment is a concrete curb or wall. We got cited for not enough secondary containment volume so our job now is to increase the secondary contaiment. We already identified concrete wall/floor type as the secondary containment. Anybody has any idea of other options to use as a secondary containment, for example direct leak to an underground reservoir and pump it back to another good tank, etc?
RE: Secondary Containment Options
DMW0001,
Thanks for the suggestion. This should work for a secondary containment where if there is a spill, it is neutralize with sodiom hydroxide.
One question, did you have experience placing this type of concrete mix at a sulfuric acid tank storage area?
Yes I spent over 3 years on this front, and I even developed a model on predicting the concrete's service life in acidic environment.
