mutiphase flow and flow splitting
My colleagues and I remembered seeing a video, well an 8mm film, of a lab where they had glass tubes to show you what happens in multiphase flow.
One of the most interesting was the split flow.  When a two phase flow in a line comes to a tee branch the flow can go straight, or take a 90 turn, almost all the liquids took the turn at the tee.  They would vary the split and sure enough, when 10% of the flow took the turn, almost 90% of the liquids went with the 10% of the gas.
We actually are seeing this.  One engineer built a "unique" slug catching facility that had a tee arrangement in it. The 12" line had a tee branch It didn't work out quite right so the field just runs the 2 12" lines open all the time.  Guess what, those 2 lines each have a separator and the separator on the line that took the 90 turn is always flooded and the dump valve cannot keep up.
The question is; has anyone else run across this old video, We'd like to give it to our field people to show them what is happening.  I've looked at youtube, no luck.
RE: mutiphase flow and flow splitting
Bob Welker at Welker Engineering used to present videos like the one you're talking about at the annual International School of Hydrocarbon Measurement (ISHM).  I haven't been to ISHM in 10 years so I don't know if he's still doing it.  You might look at the Welker Engineering web site.
David
This has some stills of glass manifolds, and a whole bunch of graphs:
http://www.google.com/url?sa=t&source=web&cd=36&ved=0CD4QFjAFOB4&url=http%3A%2F%2Fntnu.diva-portal.org%2Fsmash%2Fget%2Fdiva2%3A123809%2FFULLTEXT01&rct=j&q=%22two-phase%20flow%22%20%22splitter%22%20video&ei=dSH4TLC2I4aKlwfhwfWOAg&usg=AFQjCNE0wL4ApmPKzOECYrZc7RKH85DlbQ&;sig2=ytB2ZK1sbEnEI3Yse6jXDQ&cad=rja
Aside:  I've messed with a bunch of wet exhaust pipes in boats, and nothing would surprise me now, including what you report.
Mike Halloran
Pembroke Pines, FL, USA
