Vacuum relielf Valves
Dear,
I am working in a cryogenic ethylene tank turnaround. The vacuum relief valves are set to open at -20 mmH20 and during manteinance they were calibrated at -28 mmH20, my question is: is there any problem with the set pressure? is the integrity of the tank at risk because of the new set pressure?
What would you recommend?
Any help?
RE: Vacuum relielf Valves
What is design pressure of tank?  If tank design is -20 then thats what the vacuum relief should be set to.
Do you mean mmHg? rather than mmH2O
Design Pressures:
Inner tank: 1000 mmH20
Outer Tank: 25 psf (inclds vac)
Ash9144: I don't see your answer as being accurate. If the tank design is -20, the set pressure should be less vacuum. The device is evaluated at contingency flow to ensure -20 tank design is not exceeded.
