River flow calculations for gabions
I am working with the native population in Panajachel, Guatemala. I am trying to design a river containment system (dikes) with 30º bank slope, covered with 9" x 2m x 4m gabions o/geotec fabric. The river gradient is 200'/mile, the width 70m, x 2m max depth (20,775 cfs)for max (1) 12hr period once a year. Normal flow is 1-4000 cfs or less. River velocity at full capacity is 21.2fps. Can I use gabion mattresses at that flow?, and if they fail, how would they fail?. Can occasional deadmen be attached to resist movement.?
RE: River flow calculations for gabions
Gabions fail in different ways. High velocity flow can lift a section of mattress and move it. Debris can snag a wire and break it and then the riprap gets carried away by the current. Alternatively, one or two missing hog rings or a missing tie wire can cause the same thing. Holes or gaps in the filter fabric can allow soil to be piped out during high flow, creating a void below the gabions. High velocity flows can also just deform the baskets leaving a very rough surface. Scour at the toe of the slope can create a hole and the mattress slides in.
thanks for the help...
The river shown in the attached section is depicted at maximum expected 1000yr flood stage (4" rain/hr.), dashed line at Agatha level (1.7"/hr). The typical river level meanders in the river basin at 200cfs in the dry season to 1-4000 cfs between storms in the rainy season. At max expected flood, we are calculating 52,972 cfs. The main culprit is a slope of 200+'/mile. I have not seen HECRAS in operation before, but I reviewed the program online and it seems dooable. I will download the program and see what I can do with it... not sure it I am experienced enough to run it but I will see. the first posting I sent has the calcs for flow.
I really quickly calc'd the shear stress at the toe of slope at: normal (Agatha) stage which is +/-10lbs/ft2 and at max stage which is +/-18 lbs/ft2. With this information you may want to investigate other types of protection. I really don't think the reno's will do the trick. Have you called MacCaferri directly and chatted with them?
there has not been any other study done, than by map analysis, transit for gradient, and visual observations and calculations for water flow.
I have contacted MacCaferri. They are looking into it now.
