12 kV 3-phase pole mounted transformer
Looking to replace a 45 KVA,12kV - 120/208V, 3-phase pole mounted transformer used for station service and am having trouble finding anyone who manufactures it because of the somewhat weird kV.
Looking to do a 1-for-1 replacement to save on time and engineering costs.
If anyone has any suggestions of a manufacturer it would be a great help.
RE: 12 kV 3-phase pole mounted transformer
I'd check with Howard:
htt
David Castor
www.cvoes.com
Pole-mount 3 phase transformers are becoming somewhat rare beasts however. If you're in a hurry, it might be more expiditious to bring UG cable from the bus fuses down and place a conventional small 3 phase padmount nearby.
I agree that 3-phase pole-mounts are not seen much - at least these days.
David Castor
www.cvoes.com
