Cooper E80 Loading
Cooper E80 Loading
Hi,All
I'm trying to determine wheather 8kip/ft (Cars) is based on single stack or double stack. If it is single stack, what additional load is needed to accomodate double stack?
Thank you all.
Thank you all.
RE: Cooper E80 Loading
Typical Cooper E80 consists of 2 engines and cars (8kip/ft, where continers sit on). I wanted to know how 8 kip/ft was established. Is 8kip/ft based on one container or two containers? or Is 8kip/ft just a design load so it doesn't matter whether a car carries one container or two containers?
Thank you.
The E-80 loading is a conservative historical design established for steam locomotives in 1830. All major railroads use the E-80 design and typically operate double stack.
htt
h
I don't know the rhyme or reason for the 8k/ft. If you consider the Cooper E80 configuration, it actually works out to be about 10.3k/ft.
www.PeirceEngineering.com
The current rating for bridges recommended by AREA is E80, although it represents a very high loading and none of the current car loadings rate as high as E80.
htt
Information on pages 7-23, 6-12, and 2-3 UNIFIED FACILITIES CRITERIA (UFC) RAILROAD DESIGN AND REHABILITATION may be of interest. Table 2-2 lists suggested design wheel loads for planning purposes.
http://www.wbdg.org/ccb/DOD/UFC/ufc_4_860_01fa.pdf
