Mobile joint between pipes
I need to join two pipes with a "mobile joint" for the extraction of gases from an electric furnace. I mean, the air cannot go out between these two pipes, but the pipes can rotate one respect the other. I want one to be fixed and the other one to have a rotatory movement.
I'm trying to find suppliers on internet, but i do not know the name of this kind of joint, so it's being quite hard to search.
Can anybody give me an eng-tip?
Thanks indeed guys.
RE: Mobile joint between pipes
See 'rotary joint'.
Mike Halloran
Pembroke Pines, FL, USA
Also 'rotary coupling' or 'rotary union'.
Mike Halloran
Depending on our pipe size, material and pressure you could consider flexible rubber couplings.
Perhaps also a "misalignment flange", basically a flanged ball joint.
Great guys, I'll give all your suggestions a try and see whether I find exactly what I need.
thanks for your kindness
"Pleased to help and grateful for help"
San Sebastian, Spain.
Metallurgical & Mechanical Engineer
I have contacted this company, I think this joint is great stuff for what I need. In case anyone has a similar problem, I leave the link.
Thank you again.
http://variacor.pagesperso-orange.fr/English-RV.html
