Text size of deviation analysis
I just got a new machine with Windows 7.
We are still running UGNX5.
The text on the deviation analysis are very small.
Where can I adjust the text size?
I tried to right click on the analysis and edit display but it just shows the colors for the lines. Nothing about the text.
I also looked under customer defaults "analysis" and modified the text size under "measurement" but this is just for the measure distance.
I also found under customer defaults, gateway, object, analysis object, and again there are no option regarding text size.
Can someone help me out adjusting the text size on "deviation analysis"
Thanks!
Thanks!
UGNX5.0.4.1 MP6 \ WinXP-SP3
Productive Design Services
www.productivedesign.com
RE: Text size of deviation analysis
Preferences -> Visualization -> View/Screen
...and in the section of the dialog labeled 'Session Settings, select the 'Calibrate' button. When the next dialog comes up, use the Horizontal/Vertical sliders to increase the 'size' of the reference circle image, selecting the 'Apply' button as you do so until you get something more acceptable to you. Note however that this change will effect ALL temporary or non-model objects seen during your NX session including CSYSs, coneheads, points, splats and any other system generated objects which are displayed in the NX graphics window.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
That is just what I need.
UGNX5.0.4.1 MP6 \ Windows 7 64bit
