Dimensions in ST sketch does not adjust size automatically when zoomi
Hi guys
I got a problem with the dimensions in my sketcher.
Normally if you zoom in or out the size of the dimension changes automatically.
For example when you zoom out, the dimension size gets bigger so it stays readable.
This feature does not work anymore, all of a sudden it stopped working.
How or where do I set this feature to work again??
Cheers
Claus
RE: Dimensions in ST sketch does not adjust size automatically when zoomi
Hi guys
Problem solved, choose PMI, choose "pixel size PMI" and done.
Cheers
Claus
