API - cycling through drawing sheets and changing name
I am at a loss to explain why the following does not work. GetCurrentSheet is not getting the sheet even though that sheet is active. Any ideas? Thanks for your help.
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swDraw As SldWorks.DrawingDoc
Dim swSheet As SldWorks.Sheet
Dim vSheets As Variant
Dim i As Integer
Sub main()
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    Set swDraw = swModel
    vSheets = swDraw.GetSheetNames
    For i = 1 To swDraw.GetSheetCount
        swDraw.ActivateSheet vSheets(i - 1)
        swModel.Rebuild swRebuildAll
        Set swSheet = swDraw.GetCurrentSheet
        swSheet.SetName "Sheet" & i
    Next i
End Sub
RE: API - cycling through drawing sheets and changing name
By the way, the Rebuild line wasn't really necessary, I was just throwing it to see if it would help and it didn't.
Try this
Dim i As Integer
Sub main()
        swSheet.SetName ("Sheet" & i)
    Next i
End Sub
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
No luck unfortunately.
It is working for me
Deepak Gupta
MathCAD 14.0
Boxer's Blog
The problem ending up being that given the above macro, multiple sheets with the same name would have existed. I changed it to first change all of the sheet names to something odd and then go back through make them Sheet1, Sheet2, ... etc
Strange as SW doesn't allow for sheets with same name in same drawing file.
Deepak Gupta
MathCAD 14.0
Boxer's Blog
