AISC 13th ed. Unstiffened Bearing Connection
On p. 10-158, under "Unstiffened Seated Connections to HSS", second paragraph, it reads:
"..The minimum HSS thicknesses are established based on the weld strength. If the HSS thickness is less than the minimum value, the weld strength must be reduced proportionately."
I'm not sure what that means. Does it imply that if I selected a 5/16" weld from table 10-6, the thickness of the HSS to which the supporting angle is welded needs to be at least 5/16"? If not, where are the thicknesses "established"?
RE: AISC 13th ed. Unstiffened Bearing Connection
In my mind, a more logical approach would be to calculate a maximum weld size, Dmax, that can be considered for calculation purposes based on the material thickness.
At some point I need to just make time to go through the entire manual page by page!
