Pump Minimum Speed and Impeller Dia
Can any one expalin indetail from where these values are taken for the calculation of pump minimum specific speed and impeller dia.
1-N=LogQ/2.3026-0.75/.0025
2-D=1840*1.15*SQRT of Head/N
Where,
in equation one, i can't understand about 2.3026 and 0.0025 and in equation 2, 1840, 1.15?
MIANCH
RE: Pump Minimum Speed and Impeller Dia
It might help if you told us where these formula came from.
These are from worleyparsons design data file.
I had to dig into the old memory bank to come up with the relevant formulae.
1.  V = sq rt (2gh) ft/sec  ( peripheral speed)
 where g = 32.2 ft/sec squared
       h = head in feet
2.  V=  3.14d * N/(12*60)
      where d= dia in inches
            N= RPM
      DIVIDE BY 12 FOR FEET
      DIVIDE BY 60 FOR FT/SEC
combine & solve both formulae for d.
Worley parsons 1.15 constant is an unknown source, probably an allowance factor.
The specific speed formulae i have no knowledge of its source at present.
Offshore Engineering&Design
