Modeling cylinders with brick elements - possible?
I'm trying to mesh a hollow cylinder in ANSYS using mapped meshing, but ANSYS doesn't seem to be able to do this. According to the documentation, it appears that this is because ANSYS requires 3 sets of 2 opposite faces on the model, like a cube.
So I guess my question is, how exactly may I mesh cylinders? Are there any tricks (aside from manual meshing, I haven't found a way to connect manually meshed areas to automatically meshed areas in an easy way) to achieving this?
The picture is basically what I want the cylinder to look like.
RE: Modeling cylinders with brick elements - possible?
Don't try to VMESH the cylinder with bricks.
