Determining maximum pipe wall wear
We have recently had a pipeline checked for wear and I wan't to determine what the maximum amount of wear (or reduction in wall thickness) before the pipe must be replaced.
We are using ASTM A53B 12" Sch 80 steel pipe with a wall thickness of 12.7mm.
The maximum pipe pressure seen in the line is 45Bar.
Unfortunately I don't have a copy of ASTM B31.3 available therefore don't have access to some of the tables.
I was looking to use the calculator on the link;
http ://www.pip ingenginee r.com/onli ne/pipewal lcalc.html
however I don't have some of the information for this type of pipe i.e Stress Value for Mat'l table A-1
If someone could offer some assistance with working on this it would be much appreciated.
http
RE: Determining maximum pipe wall wear
ht
When I enter this value into the formula I get a wall thickness of 73.8mm!
The values I have used are:
Pipe O.D (mm.) 300
Internal Design Pressure (barg) 52.53
Stress Value for Mat'l from Table A-1 (N/mm2) 9.722
Quality Factor ,E 0.8
Corrosion Allowance (mm) 1.58
Coefficient,Y (mm) 0.9
Can you see where I have gone wrong?
(type it here)-> [ ]
http
9722 kPa is the ALLOWABLE PRESSURE for 300mm sch 80,
NOT the allowable stress!
Allowable stress is 137800 kPa, put that in the online calculator.
Using 137800kPa = 137.8N/mm2
I got a wall thickness of 7.7mm.
Cheers.
