NX6 Toolbars saved
NX6 Toolbars saved
I recently got a new computer and everything worked out fine with NX, except that it is not utilizing the toolbars that I had set up on my old computer.
Is there a way to bring up my old toolbars, either pulling a file off of back-up, or any other way?
RE: NX6 Toolbars saved
C:\Users\<username>\AppData\Local\Unigraphics Solutions\NX6
...and copy & paste the 'user.mtx' file from there to the same location on your new system, replacing the file of the same name that you will find there. Then simply restart NX and you should see the same toolbar and menu layout that you had before.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
use the Windows Key + R
type into the textfield :
%appData%
enter/Return
