Break-out section view in section view
Hello friends,
I'm drawing a gearbox and need to draw a section view through a dividing plane. There is a shaft and a gear in this section so i have made them non-sectioned in a section properties. Now i need to make a break-out section view in this section view because of a parallel key detail in a joining the shaft and the gear. But there is a problem, NX doesn't make break-out section trough it because the shaft and the gear are marked as non-sectioned. Could someone help how to do break-out section view in section view through an earlier non-sectioned marked component?
Thanks for answer
Thanks for answer
RE: Break-out section view in section view
assembly cut then you can do a breakout secton view in drafting
Andreas
Then go to your drawing and add a base view. Now you can select your PMI Section View and you can create a break-out section in this view.
Andreas
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
